Hello Guest it is October 24, 2026, 06:05:39 PM
Author Topic: Spindle  (Read 7362 times)
Offline cncmagic
  •  137 137
  • what me worry? heck...it ain't my machine anyway
Spindle
« on: December 01, 2024, 08:19:16 AM »
is there a method to leave the spindle running after the program (Gcode) completes? I don't see anything in the settings  :o
any semblance of information posted to anything remotely  close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
Offline thosj
  •  542 542
Re: Spindle
« Reply #1 on: December 01, 2024, 09:55:50 AM »
I guess you'd have to make sure the gcode for the end of the program didn't issue an M5 or M30. Maybe an M1 to just stop, not shutting off the spindle or coolant??
Tom
Offline cncmagic
  •  137 137
Re: Spindle
« Reply #2 on: December 01, 2024, 11:22:51 AM »
yes, that works.. also an M99.. but that causes all sorts of issues with my application.. too long a story for now but I need to use an M30.. its not a deal breaker... we normally only run at one speed so I can setup the spindle servo to simply use a start command and go at a preset speed. I'm already thinking I'll need to use the plc we have on the machine to control the spindle speed as needed. For an application that only drills two holes this turned out to be a real bastard of a project, a near vertical learning curve, and hundreds of hours of testing and troubleshooting. Sheesh..  :o
