Hello Guest it is November 10, 2026, 01:38:43 AM
Author Topic: Edge finder probing  (Read 73970 times)
Edge finder probing
« on: November 22, 2024, 10:41:35 AM »
I have downloaded some files for edge finder which after a little works does work, what I would like is for the probe to back off 5-10 mm when it has found the edge; below is the script I use and would be grateful for ang suggestions. Cheers Tony
Rem VBScript To probe bottom edge
If GetOemLed (825) NE 0 Then 'Check to see if the probe is already grounded or faulty
   Code "(Probe plate is grounded, check connection and try again)"
Else
   FeedCurrent = GetOemDRO(818) 'Get the current settings
   XCurrent = GetDro(0)
   Current = GetDro(1)
   Code "G4 P1" 'Pause 1 second to give time to position probe plate
   Code "F100" 'slow feed rate to 100 mmpm
   Rem Probe up
   YNew = YCurrent + 75
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
   Code "F" &FeedCurrent 'restore starting feed rate
   Call SetDro (1,Abs(getoemdro(1000))/(-2))
End If
Rem End of To probe bottom edge script.
Offline TPS
  •  2,627 2,627
Re: Edge finder probing
« Reply #1 on: November 23, 2024, 02:02:47 AM »
this should do what you want:
Code: [Select]
Else
   YCurrent = GetDro(1)
   Rem Probe up
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
   'move Y Axis away ----------------------------
   Sleep(200)
   G90wasON =GetOEMLed(48)
   Code "G91"
   Code "G1 Y-10"
   While Ismoving()
   Wend
   If G90wasON = True Then
      Code "G90"
   End If
End If
not tested just written down
« Reply #2 on: November 23, 2024, 01:02:35 PM »
 Hi I have tried the suggestion out today and unfortunately it comes up with Scripter Compiler Error, Cheers Tony
Offline TPS
  •  2,627 2,627
« Reply #3 on: November 24, 2024, 05:51:53 AM »
OK try this
Code: [Select]
If GetOemLed (825) Then 'Check to see if the probe is already grounded or faulty
Else
   Rem Probe up
   Code "G31 Y" &YNew
   While IsMoving()
   Wend
   Sleep(200)
   Code "G91"
   Code "G1 Y-10"
   While Ismoving()
   Wend
      Code "G90"
   End If
End If
the compiler error is in the original script:
« Reply #4 on: November 27, 2024, 02:33:48 AM »
Hi thank you for the new suggestion, unfortunately it gave me the same result, Scripter Compiler Error.
  Cheers Tony
Offline TPS
  •  2,627 2,627
« Reply #5 on: November 27, 2024, 05:09:22 AM »
the code is working here.
copy and paste the code into VB Scripter window
and use the ||> button to step through the code.
the VB Scripter will tell you, where the Scriper Compiler error should be.
« Reply #6 on: December 02, 2024, 06:22:49 AM »
Hi TPS thank you for your help, I have now got the edge finder working on X and Y axis in both directions. I have had to walk away and have a think about the software but now works great. Cheers Tony
