Hello Guest it is October 24, 2026, 08:41:29 PM
Author Topic: M03 don't fire  (Read 9637 times)
M03 don't fire
« on: November 21, 2024, 05:59:16 PM »
Hi
I have made a plasma cutter with MACH4 and Pokeys57CNC.
Movement and probing works fine, If I press button "Spindle on CW" in MACH4 screen, Cutter starts firering well.
If I send M03 in Gcode or via the MDI screen nothing happend.
Any idea?
BR
Gerhard
Offline cncmagic
  •  137 137
  • what me worry? heck...it ain't my machine anyway
Re: M03 don't fire
« Reply #1 on: November 23, 2024, 04:30:48 PM »
i'm not sure... however have you tried putting an 'S' code in the line with the M03? Could be that the Gcode won't turn it on at zero speed.  :o
any semblance of information posted to anything remotely  close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
Re: M03 don't fire
« Reply #2 on: November 23, 2024, 07:51:17 PM »
yes, I do, write
M03
S300
The speed will be displayed but the spindle on don‘t switch on.
Pokeyes guy told me MACH4 had some saftey option included now, but it seems nobody knows which options
that are
BR
Gerhard
Re: M03 don't fire
« Reply #3 on: November 25, 2024, 01:45:42 PM »
You need to put the S command before the M3 command.
I just made a thread about spindle issues.  One of my findings was the M3 not starting the spindle if there was an S0 or SNULL to begin with.  So... m3 then s300 won't work, or hasn't on the last version of Mach4 lathe.
Chad Byrd
Re: M03 don't fire
« Reply #4 on: November 25, 2024, 03:43:11 PM »
I will try it, but I have the problem on a plasma cutter not a lathe
I have found a new version from MACH4 -> 5536.
In this version fire plasma seems to work. Have only try without cutter
see only relais switching.
In this version are a lot of new buttons and functions.
Have everyone a manual or description of the 5536 plasma screen?
BR
Gerhard
