Hello Guest it is October 25, 2026, 12:24:22 AM
Author Topic: PMDX-122 & Analog Signal Output Help!  (Read 13905 times)
« on: November 01, 2024, 05:31:26 AM »
Hello guys,
Hope you can help me,, can someone tell me how to make analog signal output (0-10vdc) with my board PMDX-122?
P.S. I try to make something to control the power of laser source throughout Mach3.
Thanks you in advance!
  •  9,374 9,374
Re: PMDX-122 & Analog Signal Output Help!
« Reply #1 on: November 01, 2024, 07:26:45 AM »
As far as I am aware the PDMX-122 cannot provide a 0-10 Volt signal. Connecting a PDMX-106 may be the way to go.
« Reply #2 on: November 01, 2024, 07:30:38 AM »
I understand you, but it's no more avaliable..
No another solution?
« Reply #3 on: November 01, 2024, 07:37:20 AM »
I also have c11g board from cnc4pc, but I don't know how to wire it exactly,,
P.s. I have also external power supply switch 12vdc that I can use it here..
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #4 on: November 02, 2024, 05:38:19 PM »
A lot of PMDX boards will take the PMDX107 spindle add on board, it may be worth checking.
« Reply #5 on: November 03, 2024, 11:00:25 PM »
At the end I have installed the C11G board from cnc4pc and it's have worked fine, now I can control the analog signal from the mill screen, but how I can control it from the plasma screen set? I have maked a dro control through Screen4, but it's not work! There are somehow to control spindle speed from plasma screen set?
