Hello Guest it is September 26, 2026, 08:07:37 AM
Author Topic: Emergency Mode  (Read 10190 times)
Emergency Mode
« on: October 30, 2024, 01:27:36 PM »
I am having "Press Reset-Emergency Mode Active" come up almost every time I start to change my DRO's or edit G-Code or start a run.  Is there something I can do about that?
Another thing:  I have a licensed Mach3 in the shop but have the demo on the house computer.  Can I have the license used on the home computer so I can use the wizards, put DXF's in Lazy CAM and produce proper G-code that will run on my shop computer.
Thanks folks,
Ray
  •  9,374 9,374
Re: Emergency Mode
« Reply #1 on: October 31, 2024, 01:43:14 AM »
Hi Ray,
With regard to the license, yes, you can use the same license on more than one computer.
Just copy the file Mach1Lic.dat from the Mach3 folder of your licensed computer and paste it into the Mach3 folder of your unlicensed  computer, do a restart and away you go.
Re: Emergency Mode
« Reply #2 on: November 04, 2024, 02:00:55 PM »
Thanks Tweakie, I now have it.
Ray
