Hello Guest it is October 24, 2026, 10:34:46 PM
Author Topic: Mach3 PCI Parallel Port expansion card  (Read 10895 times)
« on: September 18, 2024, 11:15:15 PM »
Hello, Mark here from Australia. Would someone be good enough to recommend a PCI Parallel Port expansion card that is compatible with Mach3.
Many thanks
Mark
  •  9,374 9,374
Re: Mach3 PCI Parallel Port expansion card
« Reply #1 on: September 19, 2024, 12:59:53 AM »
Whichever you choose make sure of the correct voltage output. https://www.machsupport.com/forum/index.php?topic=34848.msg239910#msg239910
« Reply #2 on: September 19, 2024, 01:05:26 AM »
Thank you.
