Hello Guest it is October 24, 2026, 08:11:59 PM
Author Topic: Mach4 visual anomoly  (Read 9701 times)
Offline Rimmel
  •  284 284
« on: August 28, 2024, 06:19:26 AM »
A button shape just started showing up randomly on the screen of the Mach4 screen (happen on a miller and lathe). It vanishes if you move the mouse over it...
A little annoying - anyone know why- how to get rid of it??
thanks
Offline cncmagic
  •  137 137
  • what me worry? heck...it ain't my machine anyway
Re: Mach4 visual anomoly
« Reply #1 on: August 28, 2024, 08:11:19 AM »
access the screen editor.. it can only be selected when Mach4 is in the disabled state... now you should be able to click the area where the button appears and this should select it...  take a look in the properties window and see if tells you what the button is.. if its nothing you want to keep right click the button and select delete. Then to close the editor, reselect SCREEN EDIT. When it asks if you want to save answer yes.. and button is deleted.   :-\
any semblance of information posted to anything remotely  close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
Offline Rimmel
  •  284 284
« Reply #2 on: August 28, 2024, 09:28:26 AM »
OK got the the foot of the problem. It seems on a toggle button it adds 2 sometimes instead of one. It adds a second one without label text. This then causes it to vanish and reappear randomly. I went through all the buttons and found the one without label text and added text to it. It would then stay when the mouse was over it. Allowing me to delete it.
thanks for the help
« Last Edit: August 28, 2024, 09:30:26 AM by Rimmel »
