Hello Guest it is October 24, 2026, 08:42:50 PM
Author Topic: Motion Devices - How robust? Orphaned?  (Read 13461 times)
Offline kf2qd
  •  157 157
« on: August 26, 2024, 05:24:37 PM »
What motion device are you using with Mach3/Mach4? I have an older SIEG KX3CNC with a Ethernet Smooth Stepper and a simple breakout board. It has performed well on that little machine. I Got hold of a Bridgeport Boss with a dead control with the intention of tearing he old control out and replacing it with as Ethernet Smooth Stepper and a newer breakout board. Was progressing along and shorted a ground to and input pin and when i next checked the ESS board was completely dead. Yes, I should not have shorted that, however briefly, but having worked with industrial controls and CNC machine for most of my adult life I did not expect the ESS to be destroyed and the breakout board to be fairly unscathed...
And then there is the problem that the ESS seems to be an orphan product now... Responce times were not the greatest back when i purchased it, but hey, life happens (I wound up in the hospital for 45 days a year ago under such cirumstances) and now it seems that the SmoothStepper site is pretty much stagnant.
What products are others using, what issues do you have with reliability, support and overall performance? I know there are those that have their issues with Mach3/4 but I have have very good results using Mach3 in a light production environment. The issue that I am now having is the hardware.
Re: Motion Devices - How robust? Orphaned?
« Reply #1 on: September 02, 2024, 12:26:27 PM »
You should checkout what cncdrive has to offer.
https://shop.cncdrive.com/index.php?categoryID=114
They offer plugins that work with mach3/4, and offer deals on software license and motion controller if you are interested in UCCNC.
Regards
Charlie M.
« Reply #2 on: September 04, 2024, 08:32:19 PM »
It sounds like you've had quite a journey with your CNC setup, and losing your Ethernet Smooth Stepper (ESS) is definitely a setback. The ESS has been a popular choice for many using Mach3/Mach4, but your experience highlights the potential challenges with relying on hardware that may no longer be actively supported.
« Reply #3 on: September 10, 2024, 05:05:44 PM »
The Smooth Stepper is a very mature motion controller.  You can use it with the C25XP:
https://cnc4pc.com/c25xp-smooth-stepper-integrated-board.html
Or maybe, considering the machines that you are working on, maybe go with closed loop steppers and a C82 which has the ability to tap into the fault and enable signals of the driver: https://cnc4pc.com/c82-dual-port-multifunction-board-b.html
Arturo Duncan
https://cnc4pc.com
