Hello Guest it is November 21, 2026, 03:06:02 PM
Author Topic: 7737 Pin Mapping to Mach4  (Read 160377 times)
« on: August 24, 2024, 08:04:42 PM »
I'm configuring my Integra finally and don't see the pin mapping from the 7737 board to Mach4 anywhere.  I see the regular J7 mapping and a list of 7737 pin functions but no mapping to Mach4 pins.  Where can I find a list for this?
Mike
Re: 7737 Pin Mapping to Mach4
« Reply #1 on: August 24, 2024, 08:13:58 PM »
which signals are you trying to map?
« Reply #2 on: August 24, 2024, 08:19:49 PM »
I'm trying to map pretty much all the signals in the 7737 functions screenshot.
« Reply #3 on: August 24, 2024, 08:53:30 PM »
Please look at the user guide for Integra:
in the user guide  page 21
J7 Port#12 Digital I/O (16 Inputs, 8 Outputs)
so use P12 in mach4 control for I/O mapping
Page 12 shows all the I/O you can map on J7 regardless 7737 is plugged in or not.
https://www.vitalsystem.com/motion/hicon/hicon_integra/manuals/Integra_Guide_7800_Series.pdf
if you recently bought 7737, the I/O mapping is removed for the 8pin green plug on 7737.  For older units it is possible.
Also look at the 7737 User manual:
https://www.vitalsystem.com/breakout_board/7737v3_wiring.pdf
you will find that
For encoders on J7/7737 starts from channel 3 to 6. no mapping required.
For stepper channels, it is 0 to 3. no mapping required
you need to enable J7 Step/Dir option in the vsiDeviceManager if you want to use the RJ45 plugs for step/dir instead of using the green plugs on Integra to connect stepper drivers.  See page 4 or 5.
« Reply #4 on: August 24, 2024, 09:22:17 PM »
Thanks for the quick reply! I guess I was thinking it was a different mapping with the 7737.
Mike
« Reply #5 on: August 25, 2024, 11:01:07 AM »
I was over thinking things it looks like too. I didn't realize I didn't have to pin map the motors.
