Hello Guest it is November 10, 2026, 01:38:51 AM
Author Topic: macro hole correction  (Read 110750 times)
« on: August 17, 2024, 08:10:17 AM »
good morning
I have this macro to drill.
Dim coordinate
Dim PrimoPunto
Open "C:\LAVORI\FORI\myFile.txt" For Input As #1
Line Input #1, PrimoPunto 'leggo la prima riga del file
Close #1
coordinate=Input(LOF(1),#1) 'leggo tutto il file e salvo le coordinate nella variabile NON SO SE OTTENGO UNA SOLA RIGA O TANTE RIGHE
Close #1 ' chiudo il file delle coordinate
Open "C:\LAVORI\FORI\FORI.nc" For Output As #1 'Apro il file per la creazione del programma cnc
Print #1, "G54 G17 G90 G00 G40" & Chr(10)
Print #1, PrimoPunto 'scrive il primo punto
Print #1, "G00 Z50" & Chr(10)
Print #1, "G01 Z5 F500" & Chr(10)
Print #1, "G83 G98 Z-10 Q3 R2 L0 F100" & Chr(10)
Print #1, "(---INIZIO PUNTI MEMORIZZATI-------)" & Chr(10)
Print #1, coordinate ' stampa coordinate foratura
Print #1, " (---FINE PUNTI MEMORIZZATI---------)" & Chr(10)
Print #1, "G80" & Chr(10)
Print #1, "M5 M9" & Chr(10)
Print #1, "M30" & Chr(10)& Chr(13)
Close #1
Speak ("faile convertito") 'Avviso Vocale
Message "FILE SALVATO = C:\LAVORI\FORI\FORI.nc "
it imports a .txt file of survey points:
X15 Y15
X33 Y37
X40 Y45
etc etc
and converts it into gcode to work:
G54 G17 G90 G00 G40
X15 Y15
G00 Z50
G01 Z5 F500
X15 Y15
X30 Y30
X40 Y40
G80
M5 M9
G00 Z50
M30
the problem arises when I launch the machining, the cnc starts going up to Z50 then down to Z5 then down to z1.8 and starts to pitch between Z2 and Z1.8 without going down, I can't solve the problem it's not in my capabilities is there anyone who can help me?
regards
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: macro hole correction
« Reply #1 on: August 17, 2024, 06:44:38 PM »
Have you tried turning the softlimits off.
« Reply #2 on: August 18, 2024, 12:22:14 AM »
Good morning Graham Waterworth
yes I tried to deactivate softlimits but it didn't solve the problem
Offline TPS
  •  2,627 2,627
« Reply #3 on: August 18, 2024, 02:04:01 AM »
from the manual:
The L number is optional and represents the number of repeats. L=0 is not allowed.
« Reply #4 on: August 18, 2024, 02:50:03 AM »
good morning TPS
I tried to eliminate "L0" and it seems to work (tried in vain), is it ok like this or do I have to modify "L?" programming is at 0 it is not in my capabilities.
thanks for the help tps
Offline TPS
  •  2,627 2,627
« Reply #5 on: August 18, 2024, 02:52:48 AM »
The L number is optional...
so IMHO it should be ok to without it.
« Reply #6 on: August 18, 2024, 03:28:21 AM »
OK TPS, I tried on a piece of wood without "L0" and it seems to work but it gives me an error, the first point executes it 2 times, let me explain: the txt file:
X15 Y15
X33 Y37
X40 Y45
etc etc
I convert it then I launch it and "x15 Y15" is executed 2 times, is there a way to correct it?
I apologize if I take advantage of your availability
regards
Offline TPS
  •  2,627 2,627
« Reply #7 on: August 18, 2024, 03:36:56 AM »
your programm contains the first point two times:
Code: [Select]
G54 G17 G90 G00 G40
X15 Y15  '<- first time at X15 Y15
G00 Z50
G01 Z5 F500
X15 Y15  '<- second time at X15 Y15
X30 Y30
X40 Y40
G80
M5 M9
G00 Z50
M30
« Reply #8 on: August 18, 2024, 03:45:52 AM »
I deleted it, now the first hole is drilled at X0 Y0 when it should be at X15 Y15
Offline TPS
  •  2,627 2,627
« Reply #9 on: August 18, 2024, 09:34:44 AM »
this is runnig here correct:
Code: [Select]
G54 G17 G90 G00 G40
G00 Z50
X15 Y15
G01 Z5 F500
G83 G98 Z-10 Q3 R2 F100
(X15 Y15)
X30 Y30
X40 Y40
G80
M5 M9
G00 Z50
M30
