Hello Guest it is November 22, 2026, 07:26:45 AM
Author Topic: Reverse stepper motor direction on driver/motor winding  (Read 13279 times)
Offline Rimmel
  •  284 284
« on: August 03, 2024, 11:14:08 AM »
Ho got a motor that runs on the Z axis the wrong way. I cannot find a setting in pokeys57cnc to reverse it. Well I think I did but it does not work.
Howewer I found in the driver instructions for the CW8060 (cnc4you.co.uk) that the motor interface can be rewired to reverse the direction.
The documentation reads:
"A+ and A- is connected to a phase winding of motor.
B+ and B- is connected to another phase winding of motor.
If you need to reversed' one of the phase windings can be reversed" (or it can be reversed in software).
I have attached a picture of the wiring, but do not understand exactly what the above statement means regarding the "one of the winding can be reversed". Does it mean simply swap A+ with A- ? Or would i have to swap A+ -> A- and B+ -> B-???
Or have just got that completely wrong???
Any help appreciated.
thanks
« Last Edit: August 03, 2024, 11:26:31 AM by Rimmel »
Re: Reverse stepper motor direction on driver/motor winding
« Reply #1 on: August 03, 2024, 01:29:32 PM »
Swap over either the A+A- OR the B+B- but not both.
Offline Rimmel
  •  284 284
« Reply #2 on: August 03, 2024, 01:40:28 PM »
Thank you.
