Hello Guest it is October 24, 2026, 10:04:17 PM
Author Topic: Travel in Wrong Direction  (Read 10804 times)
« on: July 25, 2024, 09:58:18 PM »
I have just got my machine going with a lot of help this forum,but when jogging the X axis is the wrong way. In other words from the Home Position, bottom-left I need to push the Left Hand arrow key to move to the right and the DRO display increasing Negative numbers. The wiring in the controller is identical for  X Y Z axis so I was hesitant to change it there. Is there any where in Mach3 to correct this problem?
Offline TPS
  •  2,627 2,627
Re: Travel in Wrong Direction
« Reply #1 on: July 26, 2024, 12:37:43 AM »
Config -> Ports&Pins -> Motor Outputs -> Dir Low active
should help
« Reply #2 on: July 26, 2024, 01:06:58 AM »
Thankyou, that did the trick
