Hello Guest it is October 24, 2026, 09:46:21 PM
Author Topic: G76 Threading problem.  (Read 50092 times)
Re: G76 Threading problem.
« Reply #10 on: August 09, 2024, 05:38:40 AM »
What was the fix?
Steve Stallings
www.PMDX.com
Offline Rimmel
  •  284 284
« Reply #11 on: August 09, 2024, 05:39:51 AM »
What was the fix?
I removed the ESS+MB3 and installed a Pokeys57CNC, all working perfectly with the same hardware. First time, no messing around.
I had a couple of issues with the Pokeys57CNC, but that was just understanding their strange "Pins" configuration.
Polabs/pokeys have a ticket based support system though and are actively supporting their products, so the solutions were quick.
  •  9,374 9,374
« Reply #12 on: August 10, 2024, 12:52:30 AM »
« Reply #13 on: October 17, 2024, 07:42:48 AM »
What made the fixed? I just found your entry and while facing the same issue on the BUild 5036 and ESS 298.
Thx for sharing.
Frank
Offline Rimmel
  •  284 284
« Reply #14 on: October 17, 2024, 08:06:40 AM »
Thx for sharing.
Frank
https://www.poscope.com/product/pokeys57cnc/
Although if I knew then what I know now I would have gone for the Pro version
https://www.poscope.com/product/pokeys57cncpro-4x25/
« Reply #15 on: October 17, 2024, 11:05:55 AM »
Thx, I got the pokeys running on my CNC Router. Still hope to find a solution for the ESS, don't want to throw it in the trash.
Anyway, thx for letting us know.
Frank
Offline Rimmel
  •  284 284
« Reply #16 on: October 17, 2024, 11:48:02 AM »
Frank
I have one running on my Miller - it's good as it doesn't need threading.
I went and tried to get help on the Warp9TD forum but it was impossible. They admit the main developer has gone (he hasn't posted for 2 years) and they aren't really supporting the Hobby Version anymore. The don't officially even support the latest version of Mach4. Pokeys does.
As far as it goes it seems the ESS is end of life (not supported any longer).
So I wish you good luck, I have 2 ESS modules sat here as paper-weights.
cheers
« Reply #17 on: October 17, 2024, 05:00:17 PM »
Thx,
As my index pulse comes from a servo spindle, I'm able to increase the length of the pulse, I will check, if this makes any difference.
I will just give it a try, if it's going any better.
Offline cncmagic
  •  137 137
  • what me worry? heck...it ain't my machine anyway
« Reply #18 on: October 18, 2024, 01:33:40 AM »
what did you find?  :o
any semblance of information posted to anything remotely  close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
Offline cncmagic
  •  137 137
« Reply #19 on: October 18, 2024, 01:54:25 AM »
for some reason the rest of the reply's didn't show when I requested what you found... thanks.. I'm going to order a pokeys and some additional h/w and do some testing... didn't know the ESS was not being supported.  :o
