Hello
Guest
it is
November 04, 2026, 04:03:01 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
old question ...how make output blink like on screnn
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: old question ...how make output blink like on screnn (Read 22026 times)
KatzYaakov
600
on:
July 14, 2024, 08:20:37 PM »
i try so many options with pmc ,with timer...feal big idiot but such simple work cant do (actualy can do but its not stable always stack some where)
thanks
in advance
cncmagic
137
what me worry? heck...it ain't my machine anyway
Re: old question ...how make output blink like on screnn
Reply #1 on:
July 14, 2024, 09:49:33 PM »
what are you referring to when you indicate output? In any case probably works best if you write in the screen PLC coding.. you should be able to either change the color or make one image disappear and one appear, and then reverse.
any semblance of information posted to anything remotely close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
KatzYaakov
600
Reply #2 on:
July 14, 2024, 10:02:42 PM »
i mean very simple reqwest
blink the output like the buton blink on screnn
as you know we can control very easy the rate of any buton ,how long blink ...
but when this screen buton attach to output the output not blink ,its always on
thanks
cncmagic
137
Reply #3 on:
July 15, 2024, 06:16:05 AM »
it needs to be done in code... there is no other means as far as I know.
Print
Pages:
1
Go Up
« previous
next »
