Hello Guest it is October 24, 2026, 09:43:22 PM
Author Topic: Mach3 to Mach4 - Thread conversion G76  (Read 13712 times)
Offline Rimmel
  •  284 284
« on: July 09, 2024, 12:58:33 PM »
Trying to convert Mach3 thread to Mach4 but seem to be struggling a little.
I am just looking to convert a M10x0.75p external thead (Mach3) to Mach 4
I am running in Lathe Mode - Diameter and METRIC.
Mach3:
Code: [Select]
G18 G21 G64 G80 G40 G98
G0 Z10.0
G0 X9.9
G95
G4 P1
G76  X9.09  Z-19.0  Q4   P0.75  J0.03  L45  H0.03  I29  C1.0  B0.01  T0
Could someone kindly post an example of a Mach4 Metric thread (in metric mode).
thanks
PS tried the MachMotion wizard and that just throws out garbage.
« Last Edit: July 09, 2024, 01:04:52 PM by Rimmel »
Offline Rimmel
  •  284 284
Re: Mach3 to Mach4 - Thread conversion G76
« Reply #1 on: July 09, 2024, 01:20:16 PM »
Its a parallel thread btw
« Reply #2 on: July 09, 2024, 02:03:32 PM »
I can't give you an example but have you looked at the 'Lathe Gcode Programming' guide in your c:\mach4hobby\docs folder? It explains G76 and the required parameters... may help you..
Offline Rimmel
  •  284 284
« Reply #3 on: July 09, 2024, 02:18:15 PM »
Yes - I've looked at the programing guide and used the achMotion wizard as well. But can get a metric thread to come out of it all. Hence my last resort of asking for an example.
thanks
