Hello Guest it is October 25, 2026, 02:33:13 AM
Author Topic: Auto change offset to match tool?  (Read 22633 times)
Offline Rimmel
  •  284 284
« on: July 08, 2024, 03:12:33 PM »
Is there any way to script to change the active offset to match the current tool - when you enter a number into the Current Tool box?
E.g If I enter "5" into the current tool box and press enter - it automatically sets the active offset to 5. (2 and 2, 3 and 3 etc etc)
thanks
Edit: I kbnow you can type T0505 in the MDI, but I use the machine for rapid development of parts and as such its a semi manual machine. Typing T*********X everytime I want to manuually change a tools is very tiresome... especially when you could just change the tool on Mach3 and it changed the offset automatically.
« Last Edit: July 08, 2024, 03:14:59 PM by Rimmel »
Re: Auto change offset to match tool?
« Reply #1 on: July 09, 2024, 02:15:18 PM »
Put this code into the OnModify script of the Current Tool DRO
Code: [Select]
local toolNum = select(1,...) --Get the number entered into the DRO
local rc = mc.mcCntlSetOffsetIndex(inst, tonumber(toolNum)) --Set the offset index
if (rc ~= mc.MERROR_NOERROR) then
mc.mcCntlSetLastError(inst, "Error Setting Offset Index")
end
return toolNum --Return the toolNum so that it is displayed in the DRO
Offline Rimmel
  •  284 284
« Reply #2 on: July 09, 2024, 02:20:02 PM »
Code: [Select]
end
Thank you  -I'll give that a go tomorrow.
« Reply #3 on: July 09, 2024, 09:28:57 PM »
thanks
You can add the following Lua Script:
Code: [Select]
function changeToolAndOffset()
    local toolNumber = scr.GetProperty("CurrentToolBox", "Value")
    local toolOffsetCommand = string.format("G43 H%d", toolNumber)
    -- Change the active tool
    mc.mcToolSetCurrent(inst, tonumber(toolNumber))
    -- Apply the tool offset
    mc.mcCntlMdiExecute(inst, toolOffsetCommand)
end
-- Bind the function to the Current Tool box event
scr.SetProperty("CurrentToolBox", "On Modify", "changeToolAndOffset")
This script will ensure that when you enter a tool number, the corresponding tool offset is automatically applied without needing to type the full command in the MDI each time.
« Last Edit: September 23, 2024, 01:41:16 AM by Tweakie.CNC »
Offline Rimmel
  •  284 284
« Reply #4 on: July 10, 2024, 05:23:42 AM »
thanks
Code: [Select]
end
Where are you adding the Lua Script? On the screenset Pageload event?
thanks
« Last Edit: September 23, 2024, 01:41:50 AM by Tweakie.CNC »
Offline Rimmel
  •  284 284
« Reply #5 on: July 10, 2024, 07:57:23 AM »
thanks
Code: [Select]
end
thanks
Couldn't get this to work. But thank you for your reply - appreciated.
« Last Edit: September 23, 2024, 01:42:24 AM by Tweakie.CNC »
Offline Rimmel
  •  284 284
« Reply #6 on: July 10, 2024, 07:57:52 AM »
Code: [Select]
end
This worked perfectly.
Thank you Sir.
