Hello Guest it is October 23, 2026, 03:56:25 PM
Author Topic: Spindle won't start - pwm bumped to minimum setting - Advice please  (Read 17490 times)
Hi, I've been running a CNC router with Mach 3 for a number of years with relatively few problems. (Finding a PC that runs XP was tricky!) It has now developed an issue with the Kress router spindle turning on. I get the message pwm bumped into minimum setting. I've had this occasionally over the years - Normally a quick 'off/on' reset will sort it out. I get an amber link light on the 'CNC Super box' controller.
I can get the spindle to come on, if I go into 'ports and pins' - Motor outputs and untick the Spindle 'step low active' button, so assume it's not a mechanical problem with the spindle motor or fuse gone.  It will not come on with the spindle F5 button, or if I try to run a program.
I tried using an old back up XML file, but still same issue.
Any help appreciated. I have attached the XML file and a couple of pics.
Thanks Dan
Re: Spindle won't start - pwm bumped to minimum setting - Advice please
« Reply #1 on: July 15, 2024, 05:52:17 AM »
You might want to check your PC parallel port signals with a scope or meter to make sure they are still activating and test the relevant optocopler on your breakout board if your system is very old.
The optocouplers are usually the small ICs, often 4-pin, that are arranged in a row near the in/out ports on your breakout board. The LEDs inside these chips can fail, resulting in a signal not firing.
If your board is old, and these ICs are through-hole components, they can be easily replaced with ones purchased from an electronics retailer, with only beginner soldering skill required.
If signals that should appear on your parallel port, do not appear, then it is likely your computer motherboard needs replacing.
I'd suggest a refurbished Win XP or Win7 box rather than searching for legacy motherboards.
« Reply #2 on: April 21, 2026, 02:16:16 AM »
Since it works when you toggle “Step Low Active”, check:
Ports & Pins → Spindle Setup: make sure PWM is enabled and min PWM isn’t set too high
Try lowering Minimum PWM (e.g. 0 or very low)
Verify Output # for spindle is mapped correctly (Ports & Pins → Output Signals)
Check pulley settings (Config → Spindle Pulleys), max speed not set too low
Also confirm your S command in MDI (e.g. M3 S1000) actually outputs a valid speed
The “pwm bumped into minimum” error often happens when Mach3 can’t output a valid PWM within your defined limits.
It sounds like the issue is related to the PWM signal or Mach3 settings rather than the Kress spindle itself. Since the spindle works when you change “Step Low Active,” the controller is still responding. Check the Spindle Setup settings, especially Minimum PWM, wiring connections, and the controller power supply. You can also try disabling PWM Control temporarily to test simple spindle ON/OFF operation.
