Hello Guest it is November 19, 2026, 01:14:19 PM
Author Topic: Lua set Jog% with a button  (Read 35176 times)
Offline Rimmel
  •  284 284
« on: July 02, 2024, 01:04:52 PM »
Hi, has someone got a snippet of code that would allow me to set the Jog Rate % via the Lua linked to a button.
I can create button and link it to the button etc....
thanks in advance....
Offline Bill_O
  •  616 616
Re: Lua set Jog% with a button
« Reply #1 on: July 02, 2024, 04:41:04 PM »
It is in 2 parts.
I put it all in the Mach Screen Load Script.
It does use some custom registers.
Part 1.
[mc.ISIG_INPUT11] = function (state)
      local AltRegH = mc.mcRegGetHandle(inst, 'iRegs0/Alt')
   local AltVal = mc.mcRegGetValue(AltRegH)
   if (state == 1) then
      if(machEnabled==1) then
         if (AltVal == 0) then
         CutSpeedMinus()
         elseif (AltVal == 1) then
         CutSpeedPlus()
         end
      end
   end
end,
Part 2
--cut speed plus function
function CutSpeedPlus()
   local CutMax = 200
   local CutNow = mc.mcCntlGetFRO(inst)
   if (CutNow >= CutMax) then
      CutNow = CutMax
   else
      CutNow = CutNow + 10
   end
   mc.mcCntlSetFRO(inst, CutNow)
end
--cut speed minus function
function CutSpeedMinus()
   local CutMin = 10
   if (CutNow <= CutMin) then
      CutNow = CutMin
   else
      CutNow = CutNow - 10
   end
end
Offline Bill_O
  •  616 616
« Reply #2 on: July 02, 2024, 04:44:34 PM »
Sorry previous post was for cut speed
Here is what i have for jogging speed
Part 1
[mc.ISIG_INPUT19] = function (state)
         JogSpeedMinus()
         JogSpeedPlus()
         end
      end
   end
end,
Part 2
--jog speed plus function
function JogSpeedPlus()
   local JogMaxS = 100
   local JogMax = tonumber(JogMaxS)
   local JogNowS = scr.GetProperty('sliJogRate', 'Value')
   local JogNow = tonumber(JogNowS)
   if (JogNow >= JogMax) then
      JogNow = JogMax
   else
      if (JogNow >= 5) then
         JogNow = JogNow + 5
      else
         JogNow = 5
      end
   end
   rc = scr.SetProperty('sliJogRate', 'Value', tostring(JogNow))
end
--jog speed minus function
function JogSpeedMinus()
   local JogMinS = 1
   local JogMin = tonumber(JogMinS)
   if (JogNow <= JogMin) then
      JogNow = JogMin
   else
      if (JogNow >= 6) then
         JogNow = JogNow - 5
      else
         JogNow = JogNow - 1
      end
   end
end
Offline Rimmel
  •  284 284
« Reply #3 on: July 03, 2024, 06:18:00 AM »
Thanks for the reply - a question if I may?
Code: [Select]
                JogSpeedMinus()
                JogSpeedPlus()
          end
What does "AltVal" represent e.g. why are you checking if it's equal to 1 or 0?
Are you checking if the AltKey is pressed or not?
thanks again
« Last Edit: July 03, 2024, 06:27:01 AM by Rimmel »
Offline Bill_O
  •  616 616
« Reply #4 on: July 03, 2024, 08:01:24 AM »
On my handheld pendant every button can have 2 things it does.
When you hold down what I call the "Alt" button it does the second operation for the button.
AltVal is just a variable that lets me know what the register is set at so i know which function to do when the button is pressed.
Offline Rimmel
  •  284 284
« Reply #5 on: July 03, 2024, 01:12:28 PM »
Hi, mine was easier - I just wanted a few buttons on the screen with preset values attached to them.
All I needed was
Calling for 10%  -  "JogSpeedSet(10)" on the button script.
Code: [Select]
function JogSpeedSet(JogSpeed)
            rc = scr.SetProperty('sliderJogRate', 'Value', tostring(JogSpeed))
end
end
I use a ShuttlePro and I am still trying to mimic the functions on that. I used to have a couple of macros I used to call to set Jog Speed on that.
You can't do that on the "Upgraded" Mach4...but you could on Mach3  ::) you can only seem to run Gcode.
Thanks again
« Last Edit: July 03, 2024, 01:15:47 PM by Rimmel »
Offline Bill_O
  •  616 616
« Reply #6 on: July 03, 2024, 03:33:37 PM »
Rimmel,
What exactly are you trying to do that can not be done in Mach4?
It is different but I found how to do everything plus a lot more.
Offline Bill_O
  •  616 616
« Reply #7 on: July 03, 2024, 03:36:45 PM »
I thought you were wanting a mechanical button.
If you just want a button in the software to change to a specific speed then yours is much easier.
I have mine set up so every push changes the speed by 5%.
Offline Rimmel
  •  284 284
« Reply #8 on: July 03, 2024, 03:37:24 PM »
Rimmel,
Run the function I last quoted from a button on the Shuttlepro
It seems you cannot. You can only run pre-assigned functions or a line of gcode.
Offline Bill_O
  •  616 616
« Reply #9 on: July 03, 2024, 03:51:41 PM »
I know nothing about the Shuttle Pro other than it exists.
Is there a Plugin for it?
Can you use the buttons as an input into Mach4?
If you can then you can do something like part 1 of my earlier examples.
