Hello Guest it is November 19, 2026, 03:52:44 AM
Author Topic: G-code from Mach3 to Mach4  (Read 54084 times)
« on: June 10, 2024, 07:20:09 AM »
I have got hold of a Wabeco F1210 milling machine with Mach4 installed. I have used Mach3 on another millingmachine for years.
Problem 1: When I generate G-codes for thread milling using the thread milling wizzard in Mach3, it will not work in Mach4.
Problem 2: I am not able to change possible or relevant settingsin Mach4, which also leads to
Problem 3: I cannot make the edgefinder move by itself to touch and determine positions.
Can anybody help?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G-code from Mach3 to Mach4
« Reply #1 on: June 10, 2024, 04:27:50 PM »
You need to explain why its not working, can you not load it or will it not run the code once loaded.
