Hello Guest it is November 23, 2026, 05:14:08 AM
Author Topic: Set UserDRO value from gcode  (Read 125490 times)
« on: May 04, 2024, 06:25:03 PM »
Is it possible to set a UserDRO value from gcode?
I found #99aaa = bbb works for OEM DROs, but trying it with a UserDRO number causes mach3 to crash.
I haven't found any documentation explaining what #99 is actually for.  I did find a reference online noting that is was possible to set a UserDRO from gcode, but the poster didn't explain how.
Offline TPS
  •  2,627 2,627
Re: Set UserDRO value from gcode
« Reply #1 on: May 05, 2024, 12:45:53 AM »
i think the only way will be to create a customised macro (m123.m1s for example) an call this in Gcode.
code for macro would be:
Code: [Select]
  DRONum = Param1()
 DROVal = Param2()
 SetUserDRO(DRONum, DROVal)
usage in G-code would be:
Code: [Select]
  M123 P1100 Q1234
« Reply #2 on: May 05, 2024, 06:09:12 AM »
Thanks.  I thought I might have to use a macro.  I wasn't sure how to send parameters to macros.  Your idea should work.
