Hello Guest it is October 24, 2026, 08:44:12 PM
Author Topic: rel 2.0.5325 ( I think it is) spindle speed range DRO not updating properly  (Read 8402 times)
Having problem with speed range dro updating.  This is located in the bottom right hand of the screen.  I don't know which variable this is or whatever but it is not updating with the called UP S command.  I believe it reads the S commanded in MDI or G code and updates that pulley range.  I have a Global Monitor set up so that cycle start will be inhibited when input shows that the HI lo gear selector is in the wrong position for teh called up speed.  My problem is that the speed range is not updating correctly.  https://youtu.be/YrZD57nxtN4  last minute elaborates on what I am talking about.  Maybe you guys can help?
