Hello Guest it is November 13, 2026, 11:37:22 AM
Author Topic: Jogging two axis with one button  (Read 28378 times)
Re: Jogging two axis with one button
« Reply #10 on: November 16, 2007, 11:28:03 AM »
Chip
Hey thanks a lot you saved me some precious time, I didn't think it would be that complicated I just didn't know where to look for mach constants and codes.
Wayne
« Reply #11 on: November 17, 2007, 12:15:24 AM »
Its to bad there isn't events like mouse key down and mouse key up.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #12 on: November 19, 2007, 01:51:34 AM »
Hi, Wayne
I no this isn't exactly what you want, Take a look at it any way.
http://www.machsupport.com/forum/index.php/topic,4897.0.html
Thanks, Chip
« Reply #13 on: November 20, 2007, 01:08:52 PM »
Chip,
Thanks for all your help all you have done is great. I basically did the same thing with the VB in Picture buttons that I made and just hit the Esc key when I needed to stop but this is still not what were looking for. The problem of  the not being able release the key and stop the movement where its needed to Stop.
Wayne
Offline Chip
  •  2,055 2,055
« Reply #14 on: November 20, 2007, 01:47:32 PM »
Hi, Wayne
Just how close do you need to be, The G00 X# Y# or an Inc MPG window move wold put you there?
Jog pendant's usuelly jog 1, 10, 100 or cont, I guess some will take an input though, looked at mod-io ?
MPG Jog wheel set to both axises ?
Where are you located.
Thanks, Chip
« Last Edit: November 20, 2007, 02:30:53 PM by afn09556 »
« Reply #15 on: November 20, 2007, 05:36:55 PM »
Not sure if it would work but could you not set up an external button for positive direct and another for negative direction. Have these buttons as OEM triggers and write a brain to Jog both axis positive when it sees one of them and jog both axis negative when it sees the other. That way it should only jog when it sees the trigger so releassing the button and it should stop. Or amybe I am not understanding what you want.
