Hello Guest it is October 25, 2026, 12:29:28 AM
Author Topic: Mach 4 screen movement like Mach3  (Read 8904 times)
Offline ROTM
  •  24 24
« on: April 19, 2024, 10:37:24 AM »
Good day.
Does Mach4 do this? In this video I found at https://www.youtube.com/watch?v=qOZLYOc7VF4&t=55s
When this guy scrolls in the gcode it moves in the screen as well..I do not see it in my Mach4 hobby.
Is there something I can do?
Thank you!
Re: Mach 4 screen movement like Mach3
« Reply #1 on: April 19, 2024, 11:31:19 AM »
Yes, you will need to edit the value of the line width of the gcode window through the 'edit screen' menu option to a larger value.
Offline ROTM
  •  24 24
« Reply #2 on: April 19, 2024, 03:07:31 PM »
Thanks I did change the line width for better visibility.
What I meant that in the video he scrolls thru his G-code the center will move around in the other display window.
If I jog with the controller or keyboard it moves but not cycling in the G-code window.
Am I missing something here?
Thank you!
