Hello Guest it is November 13, 2026, 10:36:55 AM
Author Topic: Pausing/stopping a program under certain circumstances  (Read 11063 times)
Offline mhdale
  •  130 130
  • Knowledge is the Treasure.
    • Black Dragon Technologies
« on: November 14, 2007, 11:46:40 AM »
Hello all, I am NOT a G-Code Guru so I am a little vague on how to set this one up so I thought I would ask the smart people :) If I have an LED on my Mach control which signifies that I want the Program  to Stop at a certain point so the operator can verify that something very critical has occured. I would like the program to STOP at a certain point only if this SCREEN LED is active... anyone have any suggestions?
Re: Pausing/stopping a program under certain circumstances
« Reply #1 on: November 14, 2007, 12:57:49 PM »
Why not just enable optional stop and put a M1 in the gcode at the point you want it to pause?
vmax549
« Reply #2 on: November 14, 2007, 01:02:47 PM »
You might want to try the BLOCK DELETE function. If the button is active then MACH will skip over Blocks of code that are preceeded with a SLASH. If the button is not active it runs the blocks. You could then program in a stop and it would only run if the BD switch is off.
« Last Edit: November 14, 2007, 01:04:46 PM by vmax549 »
Offline mhdale
  •  130 130
« Reply #3 on: November 14, 2007, 02:58:01 PM »
Thats a good idea! I could use that as there is very little call for it otherwise with this setup. Thanks!
