Hello Guest it is October 25, 2026, 02:08:42 AM
Author Topic: ESS + MB3 wiring help  (Read 112606 times)
Offline Rimmel
  •  284 284
« on: April 02, 2024, 08:35:24 AM »
Hi, I'm OK with most of the wiring to the MB3 but can't find an example for the index encoder.
I'm using a OMRON E6B2-CWZ6C Rotary Encoder, I need index Z and incremental A or B channel.
Here is the encoder pdf  https://assets.omron.eu/downloads/latest/datasheet/en/q085_e6b2-c_incremental_rotary_encoder_40_mm_datasheet_en.pdf?v=8
Also the MB3 manual, it has every example except for a rotary encoder. I have posted on the cncroom forum but it seems dead.
https://cncroom.com/wp-content/uploads/downloads/MB3-Owner-Manual-E20R2.pdf
I want to run the encoder in Counter clockwise (CCW) mode, do I use A or B?
Any help appreciated
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: ESS + MB3 wiring help
« Reply #1 on: April 05, 2024, 01:20:02 PM »
What are you using the encoder for?
In most cases you need A and B to give you the count, the Z channel can be used with the homing but you also need a switch to say you are close to the home position and then use the Z channel to find the exact point.  So you need a motion card that can handle precise homing or 2 stage homing or slow down homing or what ever they call it on there system.
