Hello Guest it is November 10, 2026, 01:39:10 AM
Author Topic: system command in the gcode  (Read 25426 times)
« on: March 30, 2024, 11:33:07 AM »
hello.
i have a custom mcode that captures a camera image, its basically running a system command to a command line image capture tool.
the macro create a unique filename for each images from the date_time_xyz then runs the capture utility
I was wondering if system commands could be called directly from the code?
Offline TPS
  •  2,627 2,627
Re: system command in the gcode
« Reply #1 on: March 30, 2024, 11:52:17 AM »
this is creating a string with date time xcoord ycoord zcoord
Code: [Select]
mystring = Date() & "_" & Time() & "_X_" & GetOEMDRO(800) & "_Y_" & GetOEMDRO(801) & "_Z_" & GetOEMDRO(802)
msgbox mystring
