Hello Guest it is November 10, 2026, 01:39:00 AM
Author Topic: passing variables from gcode to macro  (Read 27169 times)
« on: March 30, 2024, 11:21:12 AM »
is it possible to send a variable from gcode to a custom m code?
my m code is capturing images from a camera, I want to pass the commanded positions to use in the image file name
thanks
Offline TPS
  •  2,627 2,627
Re: passing variables from gcode to macro
« Reply #1 on: March 30, 2024, 11:27:46 AM »
from Mach3_V3.x_Macro_Prog_Ref.pdf:
Code: [Select]
'Example:
‘ This macro expects three arguments: P, Q, & R
‘ If put into an M-macro, and invoked via MDI, it will
‘ display the argument values on the status line
‘ For example, if using M1200:
‘ M1200 P1.234 Q2.345 R3.456
‘ Executing the above line to MDI will display:
‘ P=1.234 Q=2.345 R=3.456
Parg = Param1()
Qarg = Param2()
Rarg = Param3()
Message “P=” & Parg & “Q=” & Qarg & “R=” & Rarg
« Reply #2 on: March 30, 2024, 11:34:52 AM »
thanks!!!
