Hello Guest it is November 07, 2026, 10:40:12 AM
Author Topic: Offsets on circles  (Read 13457 times)
Offsets on circles
« on: November 13, 2007, 08:05:21 PM »
[this pertains to LazyCam Pro 2.58]
Ok, I'm really confused here so I thought I'd throw this out there for you to help out. I've created a .500 diameter circle and would like to cut out the outside diameter,  hence the need for an offset. Now first I check the scale and indeed it is .500.
I'm going to use a .125 endmill so I load the tool in the offset screen/tab and choose "outside" in the dropdown box. I clck on "create offset". Now the offset line shows up and enlarges the black border, but when I click to check the scale, it only grew .125 in size. Since it's a diameter, shouldn't it have grown twice the cutter diameter since it has to go around the .500 diameter?
Something isn't right, and it might just be me! lol!
Your thoughts?
Offline docltf
  •  354 354
Re: Offsets on circles
« Reply #1 on: November 13, 2007, 10:40:33 PM »
twice the radious of the cutter. rad .0625 plus dia .500 plus rad .0625 = dia .625
« Reply #2 on: November 14, 2007, 03:55:26 AM »
Thanks so much for your help but I don't understand as that makes no sense to me, shouldn't the offset be for the whole diameter X 2 since I'd like the end result to be .500 and not .375,? The machine ended up cutting just that, .375 diameter just like it showed in the software.
So may I ask how you setup to get the result of .500?
Thanks again,
Offline docltf
  •  354 354
« Reply #3 on: November 14, 2007, 05:56:31 AM »
when you outside offset a .500 circle with a .125 cutter lcam will show two circles .500 and .625 then you have to delete the .500 circle before you generate the code.if you don't it will cut both circles.
« Reply #4 on: November 14, 2007, 10:19:40 AM »
Yes sir, I did just that as I watched the video as well. There's still something going on here that I don't understand. I'm going to try and "trick" the software and use a 1/16th cutter and see what happens. That should actually work but I'll have to wait until I get home from work to try it.
It's still not a fix but if it works, I guess it's the best I can do.....Thanks again for your help-
« Reply #5 on: November 14, 2007, 05:00:04 PM »
Ok, success after work today and it was definitely me. I thought I had been deleting the original chain but in fact I wasn't. Thanks again for your help doc, it's appreciated-  ;)
