Hello Guest it is October 24, 2026, 01:43:35 AM
Author Topic: input to stop machine  (Read 15042 times)
Offline Bill_O
  •  615 615
« on: March 26, 2024, 07:18:07 AM »
We have a new machine and I am going to be putting a pressure sensor on so if the air pressure gets too low the machine will stop.
What would be the best place to put the code?
PLC Script?
Signal Script?
Any other place?
Open to any ideas.
Bill
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: input to stop machine
« Reply #1 on: March 27, 2024, 09:59:15 AM »
Why not just wire it through the e-stop circuit.
Offline Bill_O
  •  615 615
« Reply #2 on: March 28, 2024, 01:49:34 PM »
Graham,
Perfect.
Offline MN300
  •  306 306
« Reply #3 on: March 29, 2024, 08:05:40 AM »
If the air pressure drops slowly enough a pressure switch could signal the impending problem with enough time to stop the machine with the feed hold. This would allow you to continue once pressure is reestablished.
« Reply #4 on: May 06, 2024, 08:21:21 AM »
MN300
We use a pressure gauge that gives two outputs at different pressures.  We set a Low Air Flag that turns on the red light to the machine but allows the machine to run still, but the No Air Flag will e stop the machine.  I handle this code in the PLC Script.
Chad Byrd
« Reply #5 on: June 25, 2024, 04:16:42 AM »
we always put in our machine emergency first loop with safty device that cheack some first condition and its must confirm before give mach on
this we do only in PMC ,its litle complex becaus in pokeys you cant use input in both pmc and lua you must not overlap but after you learn how use it its good
