Hello Guest it is October 21, 2026, 10:10:42 AM
Author Topic: Plywood Router w/ closed loop servo control  (Read 108621 times)
Offline koep
  •  23 23
« on: March 11, 2024, 12:44:43 PM »
Hi Everyone!
This is a story of my recent router build and how it almost turned to personal battle.
A while back friend of mine was retiring and figured he wanted a small cnc machine as hobby.
He sent me a pic of a 3018 router with price tag of app.$300 and
another, only slightly strudier asking for around $1300.
Having built 5 machines that are run daily on business production I was quick to get on
my high horse and told him that those are ridiculous prices and that he'd get better and cheaper by building
it himself. I promised to help
I had already done a working closed loop speed control for brushed dc motor based on stm blue pill board and a carton
of reliance-electric e240 motors with heds encoders I saw as error purchase for my future uses so I figured
this should be a breeze.
I figured that the dynomotion kflop controls that I have used on previous builds are overkill for this 12"*16" router
with plywood frame so I went looking for something way less expensive and ofcourse I came across the bitsensor red board.
First build went ok only took me 8 weeks instead the planned 6 evenings.
First test cuts were ok so my friend picked the router up and I told myself welldone and started looking for other projects.
Boy was I wrong!
After a month my friend told me that the machine is getting increasing amount movement errors that at the end made the router
unusable.
I got the router back and dove in to the rabbit hole :(
After 18 months of pulling my hair, 1 usb isolator, 2 different controllers, 2 toasted heds encoders and 3 full wiring jobs
trying to find cause for what I suspected to be emi noise/ground loops
I finally found that my controller PID loop was able to read the position wrong due to how the over/underflow was handled.
After fixing that it now seems solid, runs 6 hours without loosing position, following error on diam 8 mm circle stays within
+-20 counts @ 1000mm/min.
It was much longer and much more educational project that I expected  :)
Some pictures below
Rgds,
Tapio
