Hello Guest it is October 27, 2026, 12:47:58 AM
Author Topic: edit button scripts  (Read 13695 times)
edit button scripts
« on: March 07, 2024, 11:48:46 PM »
1...installed camera.. use button "set variable position"  "go to variable position" and "stop teach"  wrote my code,,when i run, i get compile error  syntax error
2... i have new buttons installed in millbitmaps folder, dont  know how to post them in place of the above mentioned buttons,, the new one are jpeg files
Offline TPS
  •  2,627 2,627
Re: edit button scripts
« Reply #1 on: March 08, 2024, 08:50:27 AM »
pls post your code
« Reply #2 on: March 08, 2024, 11:43:36 AM »
G00 Z .100
G00 X0 Y0
FOR ONE BUTTON
GOO Z .100
G00 X-.3415
G00 Y -3.140
FOR ANOTHER BUTTON
NEXT BUTTON SAME AS 2ND ONE WITH POSITIVE INSTEAD OF NEGATIVE MONVES
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 09, 2024, 01:53:04 AM »
to excecute G-Code via button script the instruction should be for example:
Code: [Select]
  Code("G00 Z.100")
  Code("G00 X0 Y0")
see:
https://www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf
for reference.
« Reply #4 on: March 09, 2024, 03:41:43 AM »
thanks
