Hello Guest it is October 24, 2026, 06:47:43 PM
Author Topic: Probing Tab Inputs  (Read 5614 times)
Probing Tab Inputs
« on: March 03, 2024, 01:03:10 PM »
I am befuddled with a simple problem using Mach4.  I am unable to change the values of any of the DROs in the Probing Tab. For instance, I cannot modify any of the values in the Probing Settings tab.  Offset Number, G code: G, Slow measure feedrate,...  Am I missing something operationally and I am not supposed to be able to change them?
Re: Probing Tab Inputs
« Reply #1 on: March 09, 2024, 04:29:23 AM »
Which build number of Mach4 are you using? Could you upload a copy of your screenset file?
