Hello Guest it is October 27, 2026, 03:58:26 AM
Author Topic: Calibration problem with Y axis  (Read 31618 times)
« on: February 12, 2024, 03:03:15 PM »
I made a router (x) 2500mm (Y)1200mm (Z) 350mm .Control board XHC Ethernet 3/4/6 Axis MACH3 CNC Motion Control Card Frequency 2000KHZ , motors CNC DSP Stepper servo drive 8A 30~100VDC Matching 86mm NEMA34 motor HBS86H Leadshine (VALLDER). 4 engines x,y,z,(and slaves).
PROBLEM
Calibration passed great for all axis except for (y). I calibrate for example 1200mm works great. MDI 1200mm works great BUT if I do MDI 500 MM ERROR 0.8 MM. BUT I ADD ANOTHER 700MM IT FINISHES EXACTLY AT 1200MM. KNOW EVERYTHING BETWEEN 0 AND 1200 MM IS error
Thank you very much in advance
P.S
I changed control boards, motor, mechanics, drivers, etc
as if it works with degrees and not mm
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Calibration problem with Y axis
« Reply #1 on: February 22, 2024, 12:42:46 PM »
Did you calculate the steps per using the screw pitch and steps per rev of the motor and any gearing or did you use 1200mm distance and the wizard?
