Hello
Guest
it is
November 13, 2026, 01:44:47 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Z Axis motor skipping
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Z Axis motor skipping (Read 25578 times)
Chip
2,055
Gainesville Florida USA
Re: Z Axis motor skipping
Reply #10 on:
November 16, 2007, 03:00:09 AM »
Hi, Edmond
I looked at one of your backup xml files there were no Config, ports & pins, Motor Output settings at all.
Post your pin assignments for your stepper board, I'll set up a basic xml for you.
Getting way late hear, Chip
edmond
12
Reply #11 on:
November 16, 2007, 05:07:05 AM »
Hi Chip
I have set up all the ports and pins right, I think I sent you the wrong file, if I open the Mach3 folder on my work pc I see Mach3Mill.xml I assume this is the right file.Will send you the right one when I get home today.I ran config check on my home Mach3 and everything is 100%.Yes it is the same pc I ran TurboCNC with the same parallel port cable.I can jog the motors fine its just the Z motor steps on its own so something is sending spikes maybe to the parallel port.Maybe I should look for another motherboard as this pc was originally a network server does that make a difference.I will check the parallel port as you suggested.
:)Thanks for all the help
Regards
Edmond
edmond
12
Reply #12 on:
November 18, 2007, 11:03:51 PM »
It appears the parallel port in the bios of my pc was set for bi directional, if I set it to EPP mode the motors are perfect no skipping on their own but I might still get a PCI Parallel Port card for my pc just for added protection.
Edmond
Chip
2,055
Reply #13 on:
November 19, 2007, 01:11:49 AM »
Hi, Edmond
Glad you got it sorted out.
Thanks, Chip
Print
Pages:
1
2
Go Up
« previous
next »
