Hello Guest it is June 09, 2024, 09:36:09 PM
Author Topic: X-Y goes crazy when hitting a radius.  (Read 899 times)
« on: February 06, 2024, 08:58:05 AM »
Funny thing is its only if I activate port2.
What could cause this?
Offline Graham Waterworth
  •  2,689 2,689
  • Yorkshire Dales, England
Re: X-Y goes crazy when hitting a radius.
« Reply #1 on: February 06, 2024, 09:04:27 AM »
Not enough info to even hazard a guess.
« Reply #2 on: February 06, 2024, 09:19:16 AM »
adress issue? printerport on motherboard running X-Y-Z runs perfectly as long as port2 is not active, no pins are assigned in port2.
additional printerport on PCI with adress 0xe00 react to inputs when I assign pins but for some reason interferes with the outputs on port1.
x-y reacts just as if the I-J-K issue ,cropcircles,
« Last Edit: February 06, 2024, 09:25:06 AM by Gotis »
  •  2,689 2,689
« Reply #3 on: February 07, 2024, 02:56:03 PM »
Crop circles could be the IJ mode setting in general config, this can also be set in your CAD/CAM output.
Do you need 2 LPT ports?
What version of Windows are you running?
What settings do you have in Port#1 and Port#2?
« Reply #4 on: February 21, 2024, 01:19:41 PM »
Problem solved.
I just uninstalled and installed again,
 same adress as before.
