Hello Guest it is October 24, 2026, 09:33:47 PM
Author Topic: Upgrade problem - 4498 to 5310  (Read 25031 times)
« on: February 04, 2024, 02:31:30 PM »
I have a lathe and a mill powered off the same install of Mach 4 - different profiles.
I have been running 4498 and ESS 258 for forever, but the mill has probes (where the lathe does not) and later versions of Mach and the ESS plugin "fix probing", so it seemed time to upgrade.
Per the instructions, I made a copy of my old Mach4Hobby directory, renamed it, and then installed the new version over the old version.
So now I have 4 profiles: my old lathe and mill profiles, and 2 new lathe and mill profiles.
Attempting to start my old lathe profile spits out a script error, per attachment. This appears to have something to do with new canned cycles as a "Loading Modules" progress widget opens ,but never progresses.
Starting the new lathe profile successfully brings up the UI, but there's no ESS config nor is my custom signal script (which has a TON of stuff in it to support my control panel) active.
(Aside - where do the signal scripts live?)
What's the way to either fix my old profile, or bring my new profile's config info into the new profile?
I assume Mill will do something similar.
Re: Upgrade problem - 4498 to 5310
« Reply #1 on: February 04, 2024, 03:34:51 PM »
This appears to be lathe-specific: the old mill profile seems to work fine (although I have not yet extensively tested it).
But it throws no script errors and my control panel works, so that's a good sign.
Offline thosj
  •  542 542
« Reply #2 on: February 13, 2024, 09:10:54 AM »
Surprised there are no answers here, but that seems to be the way now.
What I do is rename the Mach4Hobby folder to something like Mach4Hobby_4498, then install the new version anew, NOT over the old version. Then I open both folders side by  side, and copy over license, plugins, profiles, screensets, docs (if any are new/different), maybe modules. You can then rename folders and go back easily to a working machine, and even switch back and forth to try and figure stuff out!!
That said, since Andy is gone from Warp9, issues between new Mach4 versions and ESS plugins don't get documented nor fixed like they used to, at least where I can find them, so it's a lot more daunting to "upgrade". Things don't work and it's sort of up to you to figure it out.  Andy used to keep us abreast of "this Mach4 version works best with this ESS plugin", but now I can't figure that out.
Oh, and signal scripts live in the screenstart script.
Good luck,
Tom
Tom
« Reply #3 on: February 13, 2024, 11:51:08 AM »
I have had this issuewhen updating to newer version of Mach4  .In my case it had to do with my custom Lathe  screen .I copied the turn cycles from a new version on Mach4 and importred them into  my old screen and all was good .
« Reply #4 on: March 03, 2024, 10:16:18 AM »
OK, I've got some free time on my hands and I've started to delve into this problem.
I've learned a few key facts so far:
1. Mach4 stores its machine configuration in a file called machine.ini in the profile directory that matches the profile in use.
2. This is a standard Windows .ini file, so it can be edited by text tools (thank Lob that the Spirit of UNIX sometimes made it into Windows!)
3. The ESS stores all its config info in the machine.ini file in a block titled [ESS]
4. Using a file comparison tool (BeyondCompare) I am now working my way through the .ini file and moving obvious config items over from the old profile to the new profile
5. The source of the LUA error is undoubtedly because the new profile uses a different screenset, and the screenset files either contain or provide a reference to the LUA scripts that run on startup.
I should be able to get a running machine again by copying over (using BeyondCompare) all my config values (where the .ini field is the same in both) from old to new, and leaving the new screenset intact. Then I have to edit the screenset file to move over all my custom LUA code.
Alternatively, I could just change the screenset in the old machine.ini file to the new one, and Mach should populate all the new ini file values with defaults on startup?
Maybe that is the easier answer?
Is there a Mach developer around who can discuss how Mach handles .ini files?
« Reply #5 on: March 03, 2024, 12:45:21 PM »
OK, some weird-ass shiznit is going on.
I copied my old machine.ini to the new profile, then changed the screenset (by editing the .ini file) to point at wxLathe.set.
That worked - it started up without error, axis responded to movement, etc.
Oddly, the jogging tab is unresponsive - it won't let me click on any of the buttons in that tab. But keyboard jogging works, although only in incremental mode (?)
Next was to add the LUA that enables my control panel. So I edited the screen set, immediately saved it as something else, then copied and pasted my functions to the bottom of the screen script. Saved that, restarted the machine, and... weirdness.
Jogging using the MPG works, and the enable/speed selector switch works, but the axis select switch was backwards, and would intermittently fail. As in, Mach would detect the switch state change 100% of the time, but sometimes the code would fall through.
Let's look at this in detail:
Here is the jog axis change code:
Code: [Select]
-- We use MPG 7
local MachMpgNumberForPendant = 7
local PendantStepSize = 0.001
local PendantDistanceX1 = PendantStepSize * 1    -- Multiply by one (0.001)
local PendantDistanceX10 = PendantStepSize * 10    -- Multiply by ten (0.01)
local PendantDistanceX100 = PendantStepSize * 100    -- Multiply by one hundred (0.1)
-- Constants for readability
local UnmapMPG = -1          -- Use this one for when Axis selector switch is set to OFF
local AxisNumber_X = 0        -- Linear axis X
local AxisNumber_Z = 2        -- Linear axis Z
-- The Pendant's Axis switch changed.
-- Need to handle this for when the axis switch is flipped while jogging is active
function PendantAxisChange()
    -- handles
    local hAxis_X
    local hAxis_Z
    local SelectAxis_X
    local SelectAxis_Z
    -- Before we do anything, we need to check if the jog handle is assigned to axis -1
    -- If it is, jog is DISABLED, so we do nothing (the act of enabling jog will read the axis switch)
    -- Otherwise we enable jog, which is BAD
    local AxisState
    AxisState, rc = mc.mcMpgGetAxis(inst, MachMpgNumberForPendant)
    if (AxisState ~= UnmapMPG) then
        hAxis_X, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT5)
        SelectAxis_X, rc = mc.mcSignalGetState(hAxis_X)
        hAxis_Z, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT4)
        SelectAxis_Z, rc = mc.mcSignalGetState(hAxis_Z)
        -- Now actual axis Selection Switch processing code
        if (SelectAxis_X == 1) then
            mc.mcMpgSetAxis(inst, MachMpgNumberForPendant, AxisNumber_X)    -- Map the MPG to control the X Axis
            mc.mcCntlSetLastError(inst, "Pendant Axis X Selected")                    -- Show a message in the Screen Set
        elseif (SelectAxis_Z== 1) then
            mc.mcMpgSetAxis(inst, MachMpgNumberForPendant, AxisNumber_Z)    -- Map the MPG to control the Z Axis
            mc.mcCntlSetLastError(inst, "Pendant Axis Z Selected")                    -- Show a message in the Screen Set
        else
            -- This is a problem, because the axis select switch is one or the other
    -- We have no high pin - so shut off jogging
            mc.mcMpgSetAxis(inst, MachMpgNumberForPendant, UnmapMPG )                      -- Unmap the MPG, so it won't control any axes
            mc.mcCntlSetLastError(inst, "ABEND - no valid axis selected on control panel!")  -- Show a message in the Screen Set
        end
     else
        mc.mcCntlSetLastError(inst, "Changed axis select while jog disabled - IGNORED")
     end
end
It's very straightforward. The switch on the control panel that enables jog maps the MPG to the axis when jog is active, and unmaps the MPG when jog is off. The test:
Code: [Select]
checks to see if the axis is not unmapped (-1), and if it is unmapped, it falls through to
Code: [Select]
     else
     end
because an axis change request when jogging is inactive can be safely ignored, and we check the state of the jog axis select switch when we enable jogging.
But here's the weirdness:
I enable jogging.
I switch the axis switch - and it works.
I switch it back - and it works.
I switch it again - and it fails.
It isn't consistent - sometimes it fails on the first switch, sometimes the fifth. But even though jogging is still enabled and the axis is mapped, that test is failing.
Even weirder, I have a button on the control panel for manual spindle on/off (it's a lathe, I use it for tailstock drilling and polishing).
Buttons generate two signals, a PRESS and a RELEASE.
Here is the code:
Code: [Select]
-- Control Panel Manual Spindle
function InputManualSpindle()
        -- Momentary pushbutton, so we get TWO signals with each button press:
        -- an "ON" and an "OFF"
        -- So check state and ignore the "OFF"
local hSpindleButton
local SpindleButtonState
hSpindleButton, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT8)      -- signal 3
SpindleButtonState, rc = mc.mcSignalGetState(hSpindleButton)
if (SpindleButtonState == 1) then
mc.mcCntlSetLastError(inst, "Control Panel Manual Spindle PRESS")
local hsig = mc.mcSignalGetHandle(inst, mc.OSIG_SPINDLEFWD)
local spinstate = mc.mcSignalGetState(hsig)
if (spindstate == 0) then         -- If spindle is off, turn it on
mc.mcSignalSetState(hsig, 1)
mc.mcCntlSetLastError(inst, "Control Panel Manual Spindle ON")
else                              -- Otherwise, turn it off
mc.mcSignalSetState(hsig, 0)
mc.mcCntlSetLastError(inst, "Control Panel Manual Spindle OFF")
end
else
            mc.mcCntlSetLastError(inst, "Control Panel Manual Spindle RELEASE")
end
end
That code now only triggers the RELEASE message, even though the Mach4 diagnostics show a distinct PRESS and RELEASE signal (and if I hold the button down, it never generates the release signal)
So the signal script is correctly catching the button press, but it is failing
Code: [Select]
in here.
Whiskey Tango Foxtrot?
« Reply #6 on: March 03, 2024, 01:37:45 PM »
OK, I have found evidence that what I thought was my reference code for the scripts may not have been the most recent version, in that some signal numbers were wrong, and I have caught a typo in a variable name.
This only underscores my conviction that having the screen load LUA code baked into the screen set where they cannot be accessed separately is a bad design.
It appears that I may have to re-debug my scripts.
« Reply #7 on: March 03, 2024, 01:55:27 PM »
OK there really is weirdness. not just typos.
This code is now "fixed" (but it isn't):
Code: [Select]
hSpindleButton, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT3)      -- signal 3
local spindstate = mc.mcSignalGetState(hsig)
end
else
end
end
In that now it catches the button press and release, it is properly grabbing the current state of mc.OSIG_SPINDLEFWD, and it is setting it to on or off depending on what the initial state was (on if off, off if on).
On the UI, the green "light" that shows if it is on or off is changing appropriately.
What is NOT happening is the spindle relay firing and the spindle starting or stopping.
I'm sure that used to work....
And when I look at the button in the screen editor, it has the action on release as "event{...}" which is not helpful.
« Reply #8 on: March 03, 2024, 04:32:55 PM »
LOL
This code is copied directly from the LUA scripting manual (https://www.machsupport.com/wp-content/uploads/2014/05/Mach4%20Scripting%20Manual.pdf),
pages 18-19
Code: [Select]
     else
     end
It has the exact same typo ("spinstate" vs "spindstate") as I had - so I guess I know where I found the code!
...and it no longer works in V5310...
« Reply #9 on: March 08, 2024, 06:52:01 PM »
I got some assistance over at Warp 9 and have some fixes:
Manual Spindle Button
Code: [Select]
local hsig = mc.mcSignalGetHandle(inst, mc.OSIG_SPINDLEON)  -- This turns on the spindle
local hsig2 = mc.mcSignalGetHandle(inst, mc.OSIG_SPINDLEFWD)  -- This turns on the UI button on screen
local spindstate, rc = mc.mcSignalGetState(hsig)
mc.mcSignalSetState(hsig2, 1)
mc.mcSignalSetState(hsig2, 0)
end
else
end
end
Jog Axis Select Switch:
Code: [Select]
    -- handles
  local hAxis_X
  local hAxis_Z
local SelectAxis_X
local SelectAxis_Z
local PanelMachMPGNumber = 7 -- setting this here because of suspicions that the "constant" we were using is getting garbage collected by Lua 5.3
-- March 8 2024
-- All of a sudden, following an update, MACH is picking up on the split second when it appears that both lines are HIGH
-- Adding noise reduction to the ESS config had not effect, so I suspect that the switch really does have both lines HIGH
-- as the switch moves across the contacts.
-- LUA does nt appear to have a native DELAY function and I'm not sure about OS dependancies so a simple delay isn't (yet) an option
-- so we need another solution
-- The status of the JOG ON light can be used as a flag. Is this yucky, or brilliant?
local hJogLight
    hJogLight, rc = mc.mcSignalGetHandle(inst, mc.OSIG_OUTPUT5)
local JogState, rc = mc.mcSignalGetState(hJogLight)
    local AxisState
    AxisState, rc = mc.mcMpgGetAxis(inst, PanelMachMPGNumber)
-- mc.mcCntlSetLastError(inst, "Entered PendantAxisChange()")        -- Hoe many times is this thing getting called per switch? The answer is TWO.
if (AxisState == AxisNumber_X) then
-- We started at X, so we must want Z
if (JogState == 1) then -- Make sure jog is active
mc.mcMpgSetAxis(inst, PanelMachMPGNumber, AxisNumber_Z)    -- Map the MPG to control the Z Axis
mc.mcCntlSetLastError(inst, "Panel Jog Axis Z Selected")        -- Show a message in the Screen Set
else
-- Should this fail like this?
-- This traps the second call
-- mc.mcCntlSetLastError(inst, "I think we want Z but the Z line isn't HIGH - ABEND")
end
else
mc.mcCntlSetLastError(inst, "Changed axis select to Z while jog disabled - IGNORED")
end
elseif (AxisState == AxisNumber_Z) then
-- We started at Z, so we must want X
mc.mcMpgSetAxis(inst, PanelMachMPGNumber, AxisNumber_X)    -- Map the MPG to control the X Axis
mc.mcCntlSetLastError(inst, "Panel Jog Axis X Selected")        -- Show a message in the Screen Set
else
-- mc.mcCntlSetLastError(inst, "I think we want X but the X line isn't HIGH - ABEND")
end
else
-- This never seems to execute
mc.mcCntlSetLastError(inst, "Changed axis select to X while jog disabled - IGNORED")
end
else
-- We somehow have a wrong axis?
-- Actually this triggers when we change the axis switch with jogging disabled
mc.mcCntlSetLastError(inst, "Jog Axis Switch does not recognize previously enabled axis - ABEND")
end
-- Disabled while we try the new regime because of debounce
    --if (AxisState ~= -1) then -- Temporarily (?) hardcoded to see if our constant was getting garbage collected in Lua 5.3
  --      hAxis_X, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT5)
    --    SelectAxis_X, rc = mc.mcSignalGetState(hAxis_X)
     --   hAxis_Z, rc = mc.mcSignalGetHandle(inst, mc.ISIG_INPUT4)
       -- SelectAxis_Z, rc = mc.mcSignalGetState(hAxis_Z)
  --      -- Now actual axis Selection Switch processing code
-- if ((SelectAxis_X == 1) and (SelectAxis_Z== 1)) then
-- This is a problem - the switch is shorted or something
-- mc.mcMpgSetAxis(inst, PanelMachMPGNumber, -1 )                      -- Unmap the MPG, so it won't control any axes
--            mc.mcCntlSetLastError(inst, "ABEND - Both control panel axis select lines are HIGH")  -- Show a message in the Screen Set
--        elseif (SelectAxis_X == 1) then
--            mc.mcMpgSetAxis(inst, PanelMachMPGNumber, AxisNumber_X)    -- Map the MPG to control the X Axis
--            mc.mcCntlSetLastError(inst, "Pendant Axis X Selected")      -- Show a message in the Screen Set
--        elseif (SelectAxis_Z== 1) then
--            mc.mcMpgSetAxis(inst, PanelMachMPGNumber, AxisNumber_Z)    -- Map the MPG to control the Z Axis
--            mc.mcCntlSetLastError(inst, "Pendant Axis Z Selected")      -- Show a message in the Screen Set
--        else
--            -- This is a problem, because the axis select switch is one or the other
-- -- We have no high pin - so shut off jogging
--            mc.mcCntlSetLastError(inst, "ABEND -Both control panel axis select lines are LOW")  -- Show a message in the Screen Set
--        end
--     else
--        mc.mcCntlSetLastError(inst, "Changed axis select while jog disabled - IGNORED")
--     end
end
