Hello Guest it is November 13, 2026, 11:09:15 AM
Author Topic: movement adjustment X-, Y-axis and Z-axis  (Read 16739 times)
Offline jacques_w
  •  6 6
  • Hai volks
« on: February 03, 2024, 03:54:50 AM »
The Mach3 program controls CNC router from Changzhou Huajiang Electrical Co, model 6040 water-cooled.
Problem
When programming in Mach3 G-code, the placement of - for example X30 Y30 Z60 - "translates" into moving in cm instead of mm. Where should I look for the solution? Various YouTube videos and discussion platforms do not provide any clues or solutions.
none
  •  9,377 9,377
Re: movement adjustment X-, Y-axis and Z-axis
« Reply #1 on: February 03, 2024, 05:33:40 AM »
Sounds like your Steps per Unit are out by a factor of 10.
On the Mach3 Settings page - run the Axis Calibration utility (Set Steps per Unit button) and follow the 'on-screen' directions to set each axis to the correct steps per unit. You will need to restart Mach after you have completed the process.
« Reply #2 on: February 03, 2024, 05:52:52 AM »
Or just divide the numbers already in the steps per unit dros by 10.
