Hello Guest it is October 23, 2026, 03:48:28 AM
Author Topic: Rotary Problem  (Read 7355 times)
Rotary Problem
« on: February 02, 2024, 09:42:34 AM »
I am using Aspire with a CNC4bie machine and Mach4. I have my A set to angular in Mach4 The Render from Vectric shows about 2.5 revolutions but when I cut it is about a half of a revolution. Also when cutting the coves on each end machine goes to left and makes one down cut and never rotates the A (shown in 1 of the photos attached). I'm at a loss on what's going on. Have atached photos of Vectric rending and what I end up with. When rotating with Gcode the chuck rotates 360 degrees.Thanks for any help.
Re: Rotary Problem
« Reply #1 on: February 03, 2024, 03:23:57 PM »
Found the problem. In Mach4 under general do not have check box under Rotary Axes rollover. this solve problem and functions as Mach3 does.
