Hello Guest it is November 19, 2026, 03:24:20 AM
Author Topic: G Code to reset origin x0 y0 after a move and then repeat this again  (Read 51671 times)
Using my plasma table & Mach 3 I want to burn out a hole that uses x0, y0, i and j to describe the circle to be cut. I then want to move say 2 inches in the X axis direction and then repeat the hole cut but want to be able reset the x0 & y0 origin for that new position so I don't have keep changing the i & j values if I want to keep moving to subsequent hole locations. What I have been doing is manually moving to the next location and manually resetting the x0, y0 origin for each hole. I want to be able to program this into the code to make the operation seamless. Any help would be great!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G Code to reset origin x0 y0 after a move and then repeat this again
« Reply #1 on: January 27, 2024, 05:31:30 PM »
G52 X-2.
do your code here
G52 X-4.
do your code
G52 X0 when you are finished
« Reply #2 on: January 27, 2024, 06:58:18 PM »
This will work! Thanks for the information. Always seems simple once you know how.
