Hello Guest it is October 24, 2026, 08:48:07 PM
Author Topic: THC module on plasma  (Read 11369 times)
« on: January 20, 2024, 03:13:25 PM »
Hi, is anyone use the module of THC in Mach4??
Can't find any useful info about that to fix my problems..
How i can say to mach4 that now i want to listen to thc (Input up/Input Down), without M03. Is a registry about that?
The problem is when i use M03, the movements of ohmic and torch on/off is erratic, after probe move is stuck, after probe not go to pierce height e.t.c.
If i cut without M03, is working great but no THC.
I have pokeys57cnc with plasmasens and i try with external THC too, same problems.
Thanks a lot guys!!
Offline RSL3577
  •  18 18
  • The New Kid On The Block
Re: THC module on plasma
« Reply #1 on: February 09, 2024, 08:54:52 AM »
What version of Mach are you using?
« Reply #2 on: February 09, 2024, 09:43:46 AM »
Mach4 V4.2.0.5036
Offline RSL3577
  •  18 18
« Reply #3 on: February 09, 2024, 10:09:07 AM »
Try build 5303.
« Reply #4 on: February 09, 2024, 10:55:27 AM »
Try build 5303.
Thanks for your help but i don't see it at downloads, the last one show the one i use. I have hobby Mach4.. maybe for that :) ??
Offline RSL3577
  •  18 18
« Reply #5 on: February 09, 2024, 01:34:07 PM »
Look in the FTP section.
« Reply #6 on: February 09, 2024, 02:21:08 PM »
Find it :) thanks a lot
« Last Edit: February 09, 2024, 02:23:41 PM by Greekart »
« Reply #7 on: February 18, 2024, 03:32:33 AM »
Hi, unfortunately i can't get rid the problems. I try a lot of development version's, I can't find information about new settings it have and now i can't start moving after arc ok signal..
You know anyway to bypass the mach4 thc module?
« Reply #8 on: February 24, 2024, 05:59:36 AM »
I think M03 and the THC module might conflict with each other. You can check to see if there are any settings in the Mach4 configuration related to THC behavior and M03 usage.
Thanks for your answer but can you explain me a little how i do this?
You use it and no problems at all?
