Hello Guest it is November 13, 2026, 06:36:04 PM
Author Topic: x y homing will not activate  (Read 34009 times)
« on: January 20, 2024, 02:44:29 PM »
when I go REF ALL my Z axis will home, then  offset itself, (WHICH IS NORMAL) BUT  then it goes back very slowly and bounce off my homing/limit switch a 2nd time setting off my reset button and turning on my DRO to green.  On my diagnostic page it show all LED lights on limit switches on.  When I activate a limit switch in DIAGNOSTICS all the lights go out on my limit lights  and all my homing LED lights go on.  I can stop my machine using my limit/homing switches and reset them.  Im operating my limit/homing switches NC so if any switch was bad I shouldn't be able to reset my system
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: x y homing will not activate
« Reply #1 on: January 20, 2024, 05:44:07 PM »
What type of switches are you using?
Do you have power wires mixed in with the home switch wires?
Are you using shielded cable for the home switches?
« Reply #2 on: January 20, 2024, 07:17:35 PM »
Im using 2 strand shielded wire.and wired it up NC.  I did have it running and homing. .  I did something today and pulled off one wire on my x axis switche and it was still able to run until I went to put it back on.  I had to reset Mach3.  If I just hit the limit / home switch it will stop showing limit switch  triggered. I would think that the machine would stop once the circuit was broken.  Only when I trip th limit switch will it stop.  Im using  small black switches with the trigger is on the side.  Im about ready ro replace all th switches.  I would think that since the switches can be reset than the homing should work as well.  Only z homes
  •  2,785 2,785
« Reply #3 on: January 21, 2024, 03:22:19 PM »
Turn off the limit switch signals in ports and pins and see what happens when you just have the home switches enabled.
« Reply #4 on: January 21, 2024, 10:09:17 PM »
I disabled all my limit switches in ports and pins and it didn't make any change. z axis still homes twice. once travels  to the switch and off sets,  and then inches up hits the limit/home switch and off sets again and then shuts down Mach3 to be reset again
« Reply #5 on: January 21, 2024, 11:16:12 PM »
Actually I went to diagnostics and found only on limit switch I didn't disable.  when I disabled it all axis DID home.
« Reply #6 on: January 21, 2024, 11:32:45 PM »
all axis switches home by bouncing off of the switch 2 times. they hit the switch and offsets, then very slowly goes back and bounces. off the switch a 2nd time.
  •  2,785 2,785
« Reply #7 on: January 23, 2024, 04:39:02 AM »
That sounds to be working okay now.  I would forget about the limit switches and set up the softlimits.  Homing works in different ways depending on the controller used.
« Reply #8 on: January 23, 2024, 08:38:27 AM »
would you know why when it homes it would hit each stop twice .  on the first contact it offset only to creep extremely slow to make a 2nd contact and off set again. also I would like to adjust the off set and it seems that when I go to homing/ limits and adjust the offset it doesn't seem to make a difference it the amount of off set.  my Y axis off sets about 1/16 of an inch just enough to hear the click of the switch
  •  2,785 2,785
« Reply #9 on: January 25, 2024, 06:10:04 PM »
Homing is controlled by the motion card, some use a fast approach and then back off to allow a slow accurate position, large machines need this more than small ones.  Some plugins have an option to turn on/off accurate homing.
