Hello Guest it is October 11, 2026, 11:22:38 PM
Author Topic: Custom Screen Set Transfer  (Read 15317 times)
« on: January 14, 2024, 12:45:52 AM »
Hello,
I adapted and converted an original screen to my machine on the desktop PC in the office, including some new images. How do I get this screen set onto my PC that is attached to the machine? I tried to insert the screen set file, but Mach4 crashes when loading the screen.
Thank you, greetings René
Offline Bill_O
  •  615 615
Re: Custom Screen Set Transfer
« Reply #1 on: January 15, 2024, 11:53:55 AM »
Just to make sure i understand.
You start M4 then go to View and Load Screen.
At that point it crashes?
« Reply #2 on: January 15, 2024, 01:41:22 PM »
Yes, thats Right.
Offline Bill_O
  •  615 615
« Reply #3 on: January 15, 2024, 02:13:11 PM »
Then i would think one of 2 things.
Bad code in your custom screen
or
different versions of the software between the desktop and the operating computer.
If it is neither of those your guess is as good as mine.
Offline cncmagic
  •  137 137
  • what me worry? heck...it ain't my machine anyway
« Reply #4 on: January 16, 2024, 09:44:06 AM »
there are some items that don't port over in the screen set itself.. did you change anything else besides the objects on the screen?  :o
any semblance of information posted to anything remotely  close to accuracy is merely coincidence. Use at you own discretion.. or play the lottery.. same odds
« Reply #5 on: January 19, 2024, 12:03:08 PM »
Hello,
Thanks for the help, the screen is now ready and it works, I have no idea why it works now, I think the file I used was damaged.
Greetings René
