Hello Guest it is November 11, 2026, 11:05:10 PM
Author Topic: Mach3 Support of G43.4 and G43.5  (Read 343552 times)
0 Members and 5 Guests are viewing this topic.
« on: January 13, 2024, 04:28:44 AM »
Hi, I have recently bought a 5-axis table-table trunnion milling machine and I'm new to both CAM and Mach3. I've reached a point in which I've been told that the command G43.4 can solve it, I was wondering if mach3 supports this command. If so what's the proper use of it?
  •  9,377 9,377
Re: Mach3 Support of G43.4 and G43.5
« Reply #1 on: January 13, 2024, 04:46:12 AM »
From the Mach3 summary of G-codes;
« Reply #2 on: January 13, 2024, 07:29:16 AM »
Thank YOU
« Reply #3 on: July 14, 2025, 03:28:03 AM »
Have you checked if your Mach3 post-processor or motion controller plugin supports TCP (Tool Center Point) compensation, which is what G43.4 and G43.5 are typically used for?
