Hello Guest it is November 06, 2026, 02:10:55 PM
Author Topic: Mach 4, Pokeys and a VFD - spindle control issue  (Read 128994 times)
« on: December 24, 2023, 11:29:47 AM »
Hi All,
I am having trouble with spindle control using CNC57 pokeys, Mach 4 and an Allen Bradley VFD.
Here is what I get;
Call for 500 RPM, get 665
Call for 1000 RPM get 783
Call for 1500 RPM get 905
Any ideas?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach 4, Pokeys and a VFD - spindle control issue
« Reply #1 on: December 24, 2023, 01:44:18 PM »
Have you set the speed range in the pulley screen, mach uses this to work out the 0-10v range.
« Reply #2 on: December 24, 2023, 07:25:19 PM »
I have not but wondered about it as I have seen the screen in Mach 4,  Thank you!  Are you aware of any print material to guide me in this process?
  •  2,785 2,785
« Reply #3 on: December 25, 2023, 06:44:50 AM »
Its just a case of selecting the pulley and entering the 0 for min speed and enter what ever you max is for the spindle, if you check the Help menu you can open the documents
