Hello Guest it is November 24, 2026, 08:08:50 AM
Author Topic: Help!! can't get table display right on milling machine  (Read 19437 times)
« on: December 05, 2023, 03:00:06 PM »
I've used mach3 on a router and it was fine. Now I have converted a small table top milling machine.
On my router the spindle moves along the x y axis and the tool is at the intersect on the table display. But on the milling machine the spindle is stationary so the display just shows the x and y axis moving and not the position of the cutting tool. I set the home at bottom left.
My brain has switched off so Please help me out.
Merv
Offline kf2qd
  •  157 157
Re: Help!! can't get table display right on milling machine
« Reply #1 on: January 14, 2024, 05:39:51 PM »
So you home position is -x -Y. All your movements in machine space will be in +x +y. A router and a milling machine are the same basic thing. As Mach runs it shows where the cut is in the current workspace (G54, G55,...)
« Reply #2 on: January 16, 2024, 08:40:30 PM »
Did you verify Machine Configuration? Make sure they match the mechanical setup of your milling machine.
