Hello Guest it is November 10, 2026, 01:39:18 AM
Author Topic: DRO reading  (Read 19988 times)
DRO reading
« on: December 04, 2023, 10:41:09 AM »
Good evening
having the need to see the read the dro in the bar
I put the following line in the script:
Message "X = " & GetOemDRO(800)
it works fine, but in the display it gives me a series of numbers
after the point, I'll try to explain better if the value of the dro is
"77,340"
in the bar I see:
"77.340000001242"
I ask anyone who is capable (since I am not) if it is possible to shorten the figures e.g.: 77,340.
I thank anyone who can help me
Greetings
Offline TPS
  •  2,627 2,627
Re: DRO reading
« Reply #1 on: December 04, 2023, 12:05:01 PM »
we had the sam thing a while ago.
Code: [Select]
Message "X = " & nFmt(GetOemDRO(800),3)
Re: DRO reading
« Reply #2 on: December 04, 2023, 12:31:43 PM »
ok TPS, it works perfectly, thanks!!!!!!
yes it's true I had the same problem some time ago
it was for saving in scan, honestly I tried
to modify it (and I wasted a lot of time!! ) but I didn't succeed
It's not within my knowledge, maybe for her it's simple, for me it's very complicated!!!!!!
thanks again, regards
