Hello Guest it is November 22, 2026, 08:01:05 AM
Author Topic: Table Vacuum Lua Script  (Read 22753 times)
« on: November 26, 2023, 07:41:21 PM »
Hello All,
Here is a copy of my script to vacuum my mill top.  My table is x=110 and y=63 inches. You will need to adjust the X and Y numbers for you mill size.
Code: [Select]
    -- |   Vacuum the table surface
    -- |   By Jim Anderson
    -- |   July 10 2016
    -- |   This program will vacuum the top of the table
    function GCodeExecute(GCodeString)
    local rc = mc.mcCntlGcodeExecuteWait(inst, GCodeString)
    if rc ~= mc.MERROR_NOERROR then
    return "GCode failed", false
      end -- if end
    end -- function end
    function TableVac()
      mc.mcCntlSetLastError(inst, "Starting Table Vacuum") -- Log Message
      local MyChoice1 = wx.wxMessageBox("Did you remove the tool from the spindle?\nClick OK to continue", "Are You Sure?",  16)
      if (MyChoice1 == 16) then -- 16 is a cancel
        return  -- exit out
      elseif (MyChoice1 == 4) then
        local MyChoice2 = wx.wxMessageBox("Did you zero Z for the Brush?\nClick OK to continue", "Are You Sure?",  16)
        if (MyChoice2 == 16) then -- 16 is a cancel
          return  -- exit out
        elseif (MyChoice2 == 4) then
          GCodeExecute("M08")   -- Dust Collector On
          GCodeExecute("G00 G53 X11.5 Y2.0")
          GCodeExecute("G01 Z0.0 F50.0")
          GCodeExecute("G00 G53 X11.5 Y61.0")
          GCodeExecute("G00 G53 X18.0 Y61.0")
          GCodeExecute("G00 G53 X18.0 Y2.0")
          GCodeExecute("G00 G53 X27.0 Y2.0")
          GCodeExecute("G00 G53 X27.0 Y61.0")
          GCodeExecute("G00 G53 X36.0 Y61.0")
          GCodeExecute("G00 G53 X36.0 Y2.0")
          GCodeExecute("G00 G53 X45.0 Y2.0")
          GCodeExecute("G00 G53 X45.0 Y61.0")
          GCodeExecute("G00 G53 X54.0 Y61.0")
          GCodeExecute("G00 G53 X54.0 Y2.0")
          GCodeExecute("G00 G53 X63.0 Y2.0")
          GCodeExecute("G00 G53 X63.0 Y61.0")
          GCodeExecute("G00 G53 X72.0 Y61.0")
          GCodeExecute("G00 G53 X72.0 Y2.0")
          GCodeExecute("G00 G53 X81.0 Y2.0")
          GCodeExecute("G00 G53 X81.0 Y61.0")
          GCodeExecute("G00 G53 X90.0 Y61.0")
          GCodeExecute("G00 G53 X90.0 Y2.0")
          GCodeExecute("G00 G53 X99.0 Y2.0")
          GCodeExecute("G00 G53 X99.0 Y61.0")
          GCodeExecute("G00 G53 X104.5 Y61.0")
          GCodeExecute("G00 G53 X104.5 Y2.0")
          GCodeExecute("G00 G53 Z0.0")
          GCodeExecute("M09")  -- Dust Collector Off
          GCodeExecute("G00 G53 X104.5 Y28.0") -- My park location
          mc.mcCntlSetLastError(inst, "TableVac Done") -- Log Message
        end -- if end MyChoice2
      end -- if end MyChoice1
    end -- function end
    -- ========== End ===========
    TableVac()
« Last Edit: November 26, 2023, 07:43:59 PM by JimAndi »
Happy Milling.
