Hello Guest it is October 25, 2026, 07:22:27 PM
Author Topic: Loosing steps Mach3 (old Version)  (Read 27565 times)
« on: November 03, 2023, 07:15:10 AM »
Hi, iam from germany. Sorry in advance for my bad english.
I have a cnc Machine already since 2016. The machine works great until i spend a relais to my cnc spindlemotor.
Since i build in the relais to control the milling spindle through gcode i loosing steps. And i dont know why.
The controlling of the axis in manualmode is also not that precise anymore if i load a huge gcode.
If i moving the axis i have a delay. It means, i push the arrowbuttons to move the axis, the axis dont stop right away.
It stops ~ 0,5seconds later. Its like lagging.
If i didnt load a gcode the controlling with the arrowbuttons at the keyboard is precise. The axis stops right away.
I hope someone can help me. thank u and best regards Marc
  •  9,374 9,374
Re: Loosing steps Mach3 (old Version)
« Reply #1 on: November 03, 2023, 08:53:07 AM »
Hi Marc,
Under the Operator tab run Check Config...
This will tell you if you have any conflict of pins in your new set-up.
« Reply #2 on: November 03, 2023, 09:34:19 AM »
I did. Thank u. But nothing happends.
I made something wrong or its a sign that everything is configured right?
  •  9,374 9,374
« Reply #3 on: November 03, 2023, 11:46:27 AM »
Hi Marc,
When using Check Config... you should get a Notepad display of any possible conflicts. Perhaps it is hidden behind the Mach screen ?
There are some issues with the Mach3 version .066 which you are using and Artsoft recommend the modified version (.062) be downloaded from their website and loaded over the top of the existing version. Make a secure backup of your existing Mach3 folder just in case. This post refers: https://www.machsupport.com/forum/index.php?topic=37291.msg255042#msg255042
The recommended version of Mach3 can be downloaded from here;
https://www.machsupport.com/downloads-updates/mach3-downloads/
« Last Edit: November 03, 2023, 11:48:14 AM by Tweakie.CNC »
« Reply #4 on: November 04, 2023, 05:40:25 AM »
I dont get a notepadfile even i installed the recommend Mach 3 Version.
I installed the recommended Version and the lagging is worster if i push the arrowbuttons to move the axis.
  •  9,374 9,374
« Reply #5 on: November 04, 2023, 05:57:05 AM »
If you attach your <your profile>.xml file (from the Mach3 folder) I will check your settings. You will need to rename the .xml file to something unique (perhaps marc.xml) in order to be able to attach it to your posting.
« Reply #6 on: November 04, 2023, 06:08:42 AM »
I hope the forum upload the file corectly
  •  9,374 9,374
« Reply #7 on: November 04, 2023, 07:55:57 AM »
I don’t have a PC here with a Parallel Port so cannot test your set-up on an actual machine until Monday.
In the meantime a couple of things for you to try – make just one change at a time to see if it makes a difference (You may need to restart Mach3 for any changes to take effect).
Disconnect your Shuttle while testing.
If you are using a wireless keyboard then this can affect things – use a wired keyboard.
1) Disable Charge Pump 2 (this is specifying Pin12 which is not an Output).
2) Try reducing your Kernel Speed to 35000 and re-tune your motors.
3) Increase your Acceleration in Motor Tuning to 600.
I will have further information on Monday.
