Hello Guest it is November 13, 2026, 05:04:31 PM
Author Topic: MachScreen Properties Box not Visible  (Read 51420 times)
« on: October 31, 2023, 01:37:38 PM »
HELP!  I can not get the Properties Dialog to appear on the screen.  Is there a key sequence that will force it to the top or center of the screen.  Full disclosure; I have designed a vertical(Portrait) screen; on a horizontal(landscape) PC' had no issues with the screen showing.  I need to do some fine tuning on the actual machine(portrait); but the properties Dialog can not be found anywhere.  Alt-Tab does not show the window, it is not outside the active screen window...
« Last Edit: October 31, 2023, 01:41:36 PM by JSAUNIER@YAHOO.COM »
Re: MachScreen Properties Box not Visible
« Reply #1 on: October 31, 2023, 03:00:39 PM »
use menu Options -> move property dlg into view.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: November 01, 2023, 08:15:07 AM »
As my wife would say, "If it was a snake it would have bit you!"  Thanks.
