Hello Guest it is October 24, 2026, 12:00:42 PM
Author Topic: Mach3 problem , using High Z T1000 router  (Read 18732 times)
« on: October 24, 2023, 11:48:42 PM »
Hi I’m hoping you can help? I have just hooked up my High-z- T1000 to Mach3 . Its moves very well and carves 3d. All axis running in a spiral pattern . This moves x,y,z at the same time.
My problem is with the home and limit switchs on the original machine.( magnetic). Under diagnostics screen , each  switch  when triggered , is seen by Mach3 and the light toggles as it should, but mach 3 will not datum to zero, just runs paste the limit switch?can anyone help please?
Offline TPS
  •  2,627 2,627
Re: Mach3 problem , using High Z T1000 router
« Reply #1 on: November 29, 2023, 12:27:03 PM »
for the X-axis you see the M1Home Led toogling in the diagnostic screen?
witch motion controller?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: November 29, 2023, 05:40:51 PM »
As a test turn of the limit switches in ports and pins and then try to home.
